I spent the drive on my low boost setting, as soon as I put it on high boost the car breaks traction in the slightest drizzle and those winding country roads at 120km/hr isnt the place to be breaking traction... too many trees around *shudder* I've found the dunlop SP9000 to be great tyres, but they arnt cheap at $350/tyre for 225/50
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i would rather pay more and put good quality into my car than have shit like i have now that u only have to replace anyway and spend more money on - im one of these people that have learnt that cheap n nasty ends up costing u more money in the long run!
always thought u car was blue from your avatar Rob hehe got a shock when isaw it was black - now i look at the avatar it is black its just i mustve been colour blind before!!
Parting with cash is always hard - but i usually just use it on stuff i need with my car - haha wish i could afford wank factor.
yeah i think i'll have an early night - invited someone over but havent heard back so thats cool. Dont want to go to work tommorrow - already depressed enough - that place will send me crazy . Was suppose to be using this weekend to fill out job application etc but i'll do that later i think.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
