  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
oooh vidz - can i be quality control? u know critics like those two old farts on SBS
"This video title Shafter while dropping the soap...... the acting was poor but the action scenes were of good quality - director Adrian really did a good job of acting and directing .... hes a real UP n comer - i give it 4 stars" :)
Originally posted by Nizmo
haha at everyone takin the piss outta paul - sooo many - too many to personally congratulate u all - hehehe :P
*shields herself from paulies wrath*
Hmmm , you didn't mind his company over the w/end.
Or were you just cold ??
Cheers
Ken:uhh:
