  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hehe yeah i'll be in on that - which cinemas?
nah its tommorrow but ive been doing a lot of stuff for it today.
Alex - u get your thingy mijig in on time? for work - the thing u were stressing about?
Adrian - about 30mins ago hahaha
Zanda - I didn't really know many yr 12s when I came in yr 11... Us roley's stuck together hahaha Yeah my best friend Juanita went out with James and Andrew hahaha, Andrew is like married now with a kid... well he got her pregnant and his mum made him marry her
its for Thursday right?
haha paul i thought everyone wouldve put their hand up for them by now!! If noone else from Sau wants to go im sure i can find somebody who wants to tag along with us.
wasn't happy thinking of that it was just that I was driving in the country, listening to Gregorian chants: Masters of chant, it was a cloudy day and rained a little and all I could do was think of the weather and how if I was to crash the car and die I would be so happy. It was as if the weather and the earth looked at me and said all this is what life is about. Relaxing drive, sound of music and the thought that it wouldn't worry me to die. Man I loved that day and think, if I could have one day, repeat over and over again, it would be that day.
^MAN I WORK WITH SOME FKED PEOPLE!!
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
    • The rod I was moving left and right you can see looking from the passenger side floor up into the center console.  IMG_8095.mov
