  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Sneeza
Aidwin - does it clear your nose out??
sneeza i bought somthing that does wonders from albany. Sandlewood factory makes this "winter blues" that you spray on your pillow. It has sandlwood oil, emu oil and Eucaluptus. I started to get a cold on the weekend. You know when you wake up with your nose all clogged up? well i sprayed some on my pillow last night and woke up with no buggers at all :D Pitty its in albany. You can possably get see if on the website if they have a distributer in perth. Seriously works great. You can spray it on a scaff or hanky and sniff it during the day and that works too :)
http://www.mtromance.com.au/
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
