  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Micko
Ken, better take me off the list for those squirters, not on the budget anymore cos I gotta do a mild upgrade (turbs only).
I reckon Brett Hackett will be keen on them though cos I was telling him about them the other day - he was asking whether you had more;)
Oops , has the war office declared war or you suddenly woke up from the dream and found that someone had to pay for it all and it's you..:D
Cheers
Ken
Originally posted by angel
Why are we all so technical tonight? Anyone comming to the movies Thursday?
Hey , don't look at me .
I'm all for down and dirty but this lot won't let me get in the gutter with you.:D
Cheers
Ken
Both Ken - actually if I think the car will be quick enough for a while just with the turbs & ecu - gotta leave some things to add on later:D
Start saving for an engine rebuild with forgies cos it aint gonna last too long knowing the
*More boost please*
Micko. Hehehe
Cheers
Ken
Hey Ken, behave. I am an impressionable young lady, and you must be careful about insinuating that unsavoury things are sliding down my throat.
Don't look at me ( again ).
Your the one that wanted it in the gutter.
Just cos it's going past your tonsils to get there....
:D:):D
Cheers
Ken
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
