  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah i dont care if i have to exit the movie for lots of alcohol induced loo stops - just make sure i have an eisle seat :)
Does Foundary have Wine Liz - when it comes to Wine im a cadbury kid haha
Ken i keep telling u boys im a :angel: :(
*niz rubs hands together* This is going to be so much fun!
Should see me drive after a couple of wines anyway - like today on the way home from work after our friday pissup - there were a couple of guys in this done up Celica i was showing off too - and by the looks on their faces impressing :) and i took on this 240Z twice and won both times - although its not hard haha think he was pretty impressed too cos my car was sideways up orrong rd for a little bit hehe :(
Originally posted by Nizmo
dont steal my Shaft away Ken haha anyone want to apply for the position of fixing my sink haha :)
Gee , shaft in the pool , now on the sink. Is there no end to your positions ??:(
Cheers
Ken
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
