  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by docile
nah, all ready to put down a deposit on an autoworx car (although a car i had a drive of at CRed was ok too) but sumthing said no.....
Found out a couple of guys at work (who i've known for ages, just never knew they had good cars) have rexes that do easy high 11's (with nos) and low 12's (without).
So after having a drive in their cars, i've decided on a rex....
Hmmm , thinks
* what is he doing on this forum then ? *
Cheers
Ken
Originally posted by PACEY
Yerr rex are good, i think it all comes down to personal preference really. My mate had an ex targa wrx running 25 psi, that was the first really fast car i drove and fuuuuuk that thing moved, still the fastest car ive been in so far.
Ex targa rex ?
Must be fairly new cos they only let them into to Targa last year.
Cheers
Ken
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
