  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Micko
Ken - is there much to be gained by having the manifolds ported whilst they are off the car? There is quite a bit of overlap on the outlet, but I'm not sure if it is designed that way to vector the gasses towards to wheel at more of an angle.
Vector the gases ??
wow , you been reading a dick and mary ?
I would suggest that smooth is the way to go with no obstruction. Turbo boost just pushes it out and you want it down the pipe as quick as possible.
Cheers
Ken
this convo sound to intermaletucal for this here chin wag
Any idea where to get it done then Ken - I got a dremmel tool but I don't think I should touch them unless I know what I'm doing...
Any head type shop can do them.
Lumpy did mine .
Cheers
Ken
bad news there rob
theres a hole in the timing the map will get that looked at. doubt it will add to much to the overall power though.
also need to get the idol sorted just needs alittle more juice to prevent the hunting, i've nearly go tit from playing with the map but not quite.
    • ouch! how is the car now?I had sold my gtr but have been looking into some on trademe and a 260RS but I wouldnt be keen on any repairs needed on them
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
