  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Picked up my rims off paul today. So now I got two 18x9" enkei rims for the rear, just need to organise some simular rims for the front. I've found the rims, just need to find a good price, best so far is a place over east which is $515/rim (18x8") and $40/pair for shipping. The rims I got off paul need a bit of cleaning up, but depending on the rubber I reckon I can get them all on for less than $2500 all up (all 4 rims and rubber) :P
Yeah will be good. Paul gave me the 2nd hand rims for $210 each they need cleaning up a bit, nothing major. But enkei dont make the RP01 rim anymore, but they do make a RP02 which is almost identical except for the middle cap. So I'll order a set of 18x8" for the front and then put some dunlop rubber on them I think, pretty happy with the dunlop sp9000's I got on the rear at the moment. Might try their super sports series if they aint too much.
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
