  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Plus someone wants my r33 turbo, so the end deal is quite attractive :) But as its sleeved and not ball bearing I want to get it fully checked if its all ok, then I will buy it, still need to do a few things before it goes on... fuel pump, fuel regulator, need to find an external wastegate, might need to change my exhaust manifold although it will bolt straight on. Plus ecu needs doing too... so it'll be a slow process over a few months, but if I get this turbo I should be able to do ecu+turbo and all that goes with it for less than $5k.
