  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
*kisses*
Night all
Thanks for a great day Liz :)
Hummph
So it was only Liz that gave you a great day and not my scintillating convo.
Well that's fine . Next time talk to yourself and get drooled over by some other guy then...
* ken goes and sulks*:)
Cheers
Ken
Originally posted by 33Spec2
nah seriously i had work bleh it sucked! otherwise i woulda com down and dynoed the n/a hahahaha:p
Shame , there was a lot of cars ( 31 I have been told by Kelly ).
Lots of people I didn't recognise.
Cheers
Ken
Russ , there was 2 R32 GTR's and I ran 2nd with the ricer.
Gav got 343 ish and I got 322ish at the rear wheels.
EvilR33 ( Brett Hackett ) in his R33 GTR came down but the girl didn't run.
Just like the other girls on here tonight....:)
Cheers
Ken
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
