  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Name's spelt Dinesh fellas, but just use Gradenko. Saves on the thinking. :P
rob77, yeah, I know what ya mean. Every bug I hit is a potentional fin bender. Really gotta go find some mesh one day. Trouble is, everyone sells gay boy rice mesh (macka style), not the wide spaced stuff I want.
