  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Paul - here's all the news according to ken:
blah, blah, blah, blah, blah, blah, blah, blah, blah, blah, blah, blah, blah, blah, blah, blah, blah, blah, blah, blah, blah, blah, blah, blah, blah, blah, blah, blah, blah, blah, blah, blah, blah, blah...
Oh, & the ricer pulled 322rwhp on the rollers...
Originally posted by MrGTST
Sorry Gradenko..... Its Troy's fault... I wasnt sure of the spelling so I just copied him :P
hey he never told me how ot spell it in the first place
liz its england stays light over there for ages in summer and the reverse in winter
and what sort of views are we talkinf about paulie
hehehe
And it's sold to Danny and just in time.
The original guy rang today as he just sold his car and he is spewing.
He REALLY wanted that ricer .
Must be one of paully's type....
Cheers
Ken
Well when I get back I will have to get you guys to check the turbo etc to see if mine has any advantages that we dont know about or if mine is just really speshal :P
Edit: Thinking about it there is no reason mine shouldnt be a stocker... Its only 10 HP higher than both your two ( Troy and Paul ) and you are bothrunnung stock turbo's ...
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
