  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by angel
I have had to lift the suspension, now I feel like I am driving a Landcruiser. Blue headlights have to go, blowoff valve, neons NOS...
Idiot officer.
NOS ???
Cheers
Ken
ps , Hi Angel, saw the car at the Dyno but no you:(
No I don't have NOS. But try telling an idiot officer that! Exhaust, air filter, replace door trims...
Door trims were off getting re-upholstered at the time, due to be picked up next day.
Return exhaust to standard! Yeh mate, going to take off a titanium exhuast system and replace with stocker!
Anyone want to swap?
Originally posted by G0DF4Th3R
Ken - a friend has an Edelbrock Nitrous System :P im trynna find out the specs, u think anyone on this forum is interested?
Try Rev210 , he is the only nutter I can think of dabbling in
Naaaaws
* F+F speak *
Cheers
Ken
Ken - thanks for the quick geography lesson - north, east, south, west, north, east, south, west, north, east, south, west, north, east, south, west, north, east, south, west, north, east, south, west, north, east, south, west, north, east, south, west, north, east, south, west, north, east, south, west, north, east, south, west, north, east, south, west...
Was difficult to keep up but I think I got the idea:bahaha:
bah this is gettin boring
everyone has left :(
Hoy , since when have we all been boring when whoring:D
Another rhyme , bwahahaha , I still got it
Cheers
Ken:D :P:D :D :D
Hehehe
Cheers
Ken
