  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hi Dylan,
Thanks for all your help last night. We had about 45 in attendance from the money we took so that was an excellent roll-up.
We could not have done this without your co-ordination
^ HIS PHUCKING CO-ORDINATION???
i did it all!! :) he just rolled up! *Blaaah!* never get any respekt around here!!
yeah i went when i was 16 and i never had been to a dentist before - they said wow for someone whos never been to a dentist ur teeth are perfect - go back this year and had to have 5 fillings ..... so probably best to have them checked out kyles. My teeth have deep grooves unfortunately - another one of those quirky things i inherited off my dad - plus my teeth are quite ground down for my age!! but i know why that is ... i grind my teeth when im stressed .... i grind my teeth when i sleep ..... in fact im constantly grinding my teeth haha
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
