  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Sorry Niz... nah I am still hyped from the stress at work hahaha and i went to the gym to calm down... didn't work.
My boss is working on it with me... so not my fault hahahaha We happened to hit a bug..... just as we were ready to release... its just that this bug kinda screwed everything
Liz sounds like u need a drink! not been a good week for u - next week start afreash and try again? Which gym do u go to?
Rob - haha oh well its what my cars got now - cleaning the mags is good therapy anyway :D
haha thanks rob .... i think. U got a ricey kit picked out for ur car yet? my back wing is currently being held together by packaging tape!
Liz thats good - exercise for some reason helps u run off some of that adreline :D
Nah... I'm not a fan of kits. I'm leaving the rear wing as is, probably just change the front spoiler for something basic... I've been trying to get a m-spec front bar so I can modify it and get a plastic welder to fix it up for me, so it would be unique. Apart from that the only other ricey thing I would put on would be a carbon fibre bonnet, but thats a long way off... my main concern in HP :D
haha the good old vodka in the water bottle and bourbon in the coke bottle eh Liz? yeah i miss my lunches andrew used tot ake me to on his day off ..... we would sit donw the pub for an hour and knock off whatever we could ...... used to go to work so much happier afterwards :D
Does your boss understand the situation?
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
