  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Russ - well cause we're going up to MY for a few days but we leave from singapore to go back to oz... singapore authorities will consider us "homeless" for those three days and might turn us back..... also we would have had to pay by tuesday.... so she said to come back after the 15th for a new package..... but we have plane seats thats the main thing hahaha
Yeah I am picking lauren up and we are training it into perth.... are you meeting us in there?
