  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha yup looks like Cam - and even u werent happy before .... u got a new one now ..... i was REALLY happy in Fleet Management .... but unfortunately thats the way life works ;)
anyway my hometime .... might be on later tonight :)
I have a money making idea... I got it off that life support show on SBS. you go into kiddies chat rooms and wait to be "picked up" by a peadophile.... then you get them to send you gifts - like playstation 2 etc etc, then sell these on EBAY.....
Its not like they will go to cops for extortion hahaha and they deserve to be f*ucked over
