  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
not much, had a spare bumper ready to go, and they did a bit of impromptu panel repair in the shed to make it look semi sorted, someone mumbled something about it hitting a pannel shop ultra early tom morn before it gets loaded onto the truck, but it wasn't to bad, nothing a ratchet strap a hammer and some rolling of the car backwards to pull stuff back into shape didn't fix..
Originally posted by GTS-t VSPEC
Ken, You not busy at Maximum anymore?
Always busy but always keen for variety ( in job, cars and women.... ):P
I only work subcontract so I come and go sort of when I want
Cheers
Ken
Originally posted by XRW
let me just print a copy of this for your wife, what was her name again ken? :P
Let me see..
What shall I tell Jules about the deep and meaningfuls and how sleepy they make you ...:D
Cheers
Ken
Originally posted by Micko
No Paul - danny never called up about the pipe
Ken - you checked if you got one?
Micko , I have pretty much all the terb set up off the old ones so I assume the pipe you want is here.
Don't know if it's bent though.
Cheers
Ken
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
