  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
not much, had a spare bumper ready to go, and they did a bit of impromptu panel repair in the shed to make it look semi sorted, someone mumbled something about it hitting a pannel shop ultra early tom morn before it gets loaded onto the truck, but it wasn't to bad, nothing a ratchet strap a hammer and some rolling of the car backwards to pull stuff back into shape didn't fix..
Originally posted by GTS-t VSPEC
Ken, You not busy at Maximum anymore?
Always busy but always keen for variety ( in job, cars and women.... ):P
I only work subcontract so I come and go sort of when I want
Cheers
Ken
Originally posted by XRW
let me just print a copy of this for your wife, what was her name again ken? :P
Let me see..
What shall I tell Jules about the deep and meaningfuls and how sleepy they make you ...:D
Cheers
Ken
Originally posted by Micko
No Paul - danny never called up about the pipe
Ken - you checked if you got one?
Micko , I have pretty much all the terb set up off the old ones so I assume the pipe you want is here.
Don't know if it's bent though.
Cheers
Ken
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
