  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
joe Nooooo its not THAT!!
u dont get a headache with that and i said my tummy was sick not feeling like there are sharp knives being shoved thru it!
i think theres a tummy bug going round or something at moment - lotta people been having sickies.
hey im moving desks again next week ..... this one has more privacy :P:(
whats so hard about things being left in the past??? i mean why me .... why do i have to have it constantly being dragged up ...... i just want everything dead and buried for phucks sake!!!!!
my ex just rang ..... after phuck knows how long .... well february was probably last time i spoke with him ..... why? why cant he just leave it alone and disappear into the sunset like they are meant too!!!
I dont know..but If ex-rings you
1.Want some thing back
2. lonely and thinking if he can back to it...
3. want a quick root
4. Wanna know your female friend's Phone number
5. want more root
6. hardly happens, relised after sooo lone lonelyness, he got it wrong and want you back... :D
cheers
Joe
yeah well he leaves for England on Friday ...... wants a beer when he gets back ...... so its a case of good-o your pissing orff .... shit your coming back ..... he's a god damn human boomerang!
i forgot to ask what the phuck is happening to Shadow!!!! man if he has so much given that cat away he wont wanna come back cos i will be waiting a tthe airport for him with an axe!! I so forgot to ask ...... i want MY phucking cat back!!!
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
