  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
no probs Rob ...... how you enjoying the new turbo buddie :D
Cam - nah im too nice to do that .... besides the way my life is going at the moment i think he's proven a point ..... even tho i hat eto admit it .... no one will love me like he does. But no didnt ansewer my phone on saturday anyway to find out what he wanted ..... again.
This week is my last week ..... yipppeeeeeee!! so happy but i did spend $250 on a Gameboy advance today ....... need an income to fund these things :) But it'll keep me amused on the way to SA
bam - i read you saying it somewhere... :D got pics.. but not here at the moment.. will post some when i get em...
lauren - you're not even in your mid 20s.. don't think that you can't find someone worthwhile.. thats just crazy...
As you may or may not have figured out the posting rules have been changed to 1 every 3 minutes.
This mainly due to a recent increase is useless and utter crap in some forums mainly the state whorethreads. The admin are decidin wheather to keep them or not. For those who want to complain, theres already an off-topic whoring section all to itself, also there is a Perth irc channel as well as a Victorian one.
So either prepare for this thread to dissappear and keep the other threads on topic or keep this thread going the way it has of late general day to day converation between a bunch of mates.
I have no problems with the direction of this thread, just be aware of the above and don't reduce it to the crap that has been happening elsewhere and it should be here to stay.
troy - understood.. why keep the history of this thread anyhows? why don't they delete it if they're having storage issues? fair enough opinions on the crap posting though...
bam - u whore.. :D should've seen some of the widebody m3 convertibles i found on the m1 out of london.. wiked cars.. would trade mine in a second... :)
lauren - look aorund.. there's quite a few people you could lean on i think you'll find...
Agreed on it taking out the "friendliness" factor.. i feel i've come to get to know quite a few of the people via this thread..
hi joel...
its not a storage issues its a content issue
with the vic and nsw clubs up and running and possible sponsors now reading the forums with more interest, some of the crap that goes on just isn't good for them as a club.
as i said earlier i see we have no problem with our whore thread as long as it stays the way it has been for the last few months.
we still need to work on some of the other threads in the WA section but thats no big issue as the off topic posts have been kept mainly to a minimum within the posts related to the relevant topic.
Cam I think i just want to get comfy now ..... sick of mind games, sick of a lot of things ..... just want something stable ..... something to come home too :D
My friends just seem to meddle. im growing tired of it .... no wonder andy always used to tell my mates to phuck off .... cos at the moment im feeling the same ...... mels mates have compeltely taken over my end of work celebrations ..... oh we are doing this and that ..... they havent even asked me what i want to do .... it shits me sooo much!!!
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
