  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
yeah i never used to be jealous but my ex kinda said if your not jealous it means you dont care and all this shit...... depends how much i liek the person more i liek them the more protective i can be.
well i am sorry but i have to agree with him, i have had girlfriends that i couldnt give a shit about, and yep, i didnt care about them...
i reckon that jealousy is definitely proportional to how much you care.
more than 20 i wouldnt be liking that .... i mean on the other hand the more they've bonked around then when your considering a relationship they've been there done that and probably wont be so tempted(?) and more happy to settle with one chick.
as you said its all about their attitude towards you .... you love each other then you both are IT doesnt matter about the past.
why should how many people a guy/girl has been with in the past count?? i mean if he/she had 10 different boyfriends in the past month then yeh he/she may not be able to commit only thing i would worry about is how many people they have been with in one night
haha Ross n Richie saying two totally different things on the jealousy issue .... interesting.
i used to be totally comfortable talking about exs etc cos in my opinion being able to talk about it is a good sign your over it - agh i dont care its in the past. But i started getting dirty looks etc so i just shut up.
Yeah saw that Snyps - he owes it all to Viagra and a lot of money i reckon.
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
