  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
yeah i never used to be jealous but my ex kinda said if your not jealous it means you dont care and all this shit...... depends how much i liek the person more i liek them the more protective i can be.
well i am sorry but i have to agree with him, i have had girlfriends that i couldnt give a shit about, and yep, i didnt care about them...
i reckon that jealousy is definitely proportional to how much you care.
more than 20 i wouldnt be liking that .... i mean on the other hand the more they've bonked around then when your considering a relationship they've been there done that and probably wont be so tempted(?) and more happy to settle with one chick.
as you said its all about their attitude towards you .... you love each other then you both are IT doesnt matter about the past.
why should how many people a guy/girl has been with in the past count?? i mean if he/she had 10 different boyfriends in the past month then yeh he/she may not be able to commit only thing i would worry about is how many people they have been with in one night
haha Ross n Richie saying two totally different things on the jealousy issue .... interesting.
i used to be totally comfortable talking about exs etc cos in my opinion being able to talk about it is a good sign your over it - agh i dont care its in the past. But i started getting dirty looks etc so i just shut up.
Yeah saw that Snyps - he owes it all to Viagra and a lot of money i reckon.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
