  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
yeah i never used to be jealous but my ex kinda said if your not jealous it means you dont care and all this shit...... depends how much i liek the person more i liek them the more protective i can be.
well i am sorry but i have to agree with him, i have had girlfriends that i couldnt give a shit about, and yep, i didnt care about them...
i reckon that jealousy is definitely proportional to how much you care.
more than 20 i wouldnt be liking that .... i mean on the other hand the more they've bonked around then when your considering a relationship they've been there done that and probably wont be so tempted(?) and more happy to settle with one chick.
as you said its all about their attitude towards you .... you love each other then you both are IT doesnt matter about the past.
why should how many people a guy/girl has been with in the past count?? i mean if he/she had 10 different boyfriends in the past month then yeh he/she may not be able to commit only thing i would worry about is how many people they have been with in one night
haha Ross n Richie saying two totally different things on the jealousy issue .... interesting.
i used to be totally comfortable talking about exs etc cos in my opinion being able to talk about it is a good sign your over it - agh i dont care its in the past. But i started getting dirty looks etc so i just shut up.
Yeah saw that Snyps - he owes it all to Viagra and a lot of money i reckon.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
