  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
He heh just need a blue light on the roofline, might as well take one from the office.....
POLICE
_______________________________
Just something that happened on the weekend to me on the freewaey. Would love to know who drives a white R33 with police blue light scaring people. ****in idiot!!!
