  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Well to get a loan for skyline i had to sort out all this insurance crap and speaking to robyn she quoted me 4 different figures (ranging from 2600-4500). If i payed it all upfront she would do it for $3400, but i couldnt do that so it was going to cost me $700 upfront and 10 monthly payments of about $370. Using monthly debits adds almost another grand on the premium. Bugger that
My mate comes goes in a week later and with a worse driving record, no NCB, almost identical car (skyline) etc (remembering i live in a much better area than him) it only cost him $2500. They seemed to stuff me around and when i cancelled (after i found out that RAC wouldnt give me a loan for skyline) they were very, very unhappy.
My excess was going to be 2500 at least.
WRX is SO much easier / cheaper for insurance.
But they are looking after my mate really well (and by the sounds of it, you too)
yeh i understand what your saying.
Im reasonably happy with the RAC and the only mods that they said no to was something like autronics, but when the time comes, what they dont know, wont hurt them.
Everything else like zorst, FMIC was cool as long as its done in a legit way.
One thing that will never change is that ALL insurance companys are wankers!
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
