  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
ok just came back from little drive from beach...
damm saw frekin more skylines on the raod then WRX... lol
and some dumm Black R32 GTST I think or could be GTR... dump it on 2nd and made massive two 5m black line infront of UWA intersection... lol
I hope it wasnt some1 I already know... dumm ass.
hey aidwin - awwwwww how come everytime i go its mediocre so i decided to stay home and it turned out good :(
Hey Shaggs, too lazy today - had enough adventures for one weekend
Nice to see you back Russ.
got a 4 point speeding fine last night
excellent
didnt even realise the speed, switched from 80km zone to 70km zone was 16 km over then all of a sudden became 26km over
BUGGA
ah well
it was all in good spirits cos i really didnt realise
anyways both cars up for sale very shortly
gonna buy a bicycle
or a motor cycle *eh eh Cam*
got 2 points left now
thats worse than Niz
cant ride a motorcycle in the wet Riaz .... well ya can but at your own risk :( haha worse than me .....better than paul :)
Got my hair chopped off ........ ahhh low maintenance (its just below my ears ..... should be back down to my shoulders by the time for autosalon tho .... and it'll be a lot more healthier than it was :)
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
