it prints all distorted
prints with coloured lines going thru the middle
and at the end it goes to carriage return and a swingarm comes up and grabs the cartridges and the cartridges keep moving.........crunch crunch.....
"warning" mechanism is jammed!! "
evry since the test page it has done it...
I followed all software took all the tapes out theres nothing stuck inside..i even uninstalled and got latest hp drivers from the homepage and somethings seriously wrong!
Ive done 2 test sheets and one calibration sheet and i had to leave it or else i was going to throw it out onto the road...
maybe im just not meant to have a printer....
whyyyyyyyyyyyyyyy!!!!!!!!!!!!!!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I cant beleive it rob......
what do i do wrong???
yeah come round on sunday as a mate of course not for business :P
What it looks like is the printer is receiving totally different instructions kinda like its a total different driver running the hp
Anyway ive checked and rechecked lotsa stuff if u could have a look to varerify that would be cool
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
