  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I believe R32's are quite a bit harder to find at the moment than the 33's..... You really want to have some idea in your mind about what you are looking for ( either 32/33 , manual/auto , turbo/non turbo, colour? , modded/stock , cheap(maybe needs a bit of work?) or one that may cost a bit more but is in better condition )and then start to have a browse around and just see whats out there..... plus there are a couple of guys on here looking to get rid of there skylines too dont forget :P
Originally posted by MrGTST
I believe R32's are quite a bit harder to find at the moment than the 33's..... You really want to have some idea in your mind about what you are looking for ( either 32/33 , manual/auto , turbo/non turbo, colour? , modded/stock , cheap(maybe needs a bit of work?) or one that may cost a bit more but is in better condition )and then start to have a browse around and just see whats out there..... plus there are a couple of guys on here looking to get rid of there skylines too dont forget :(
cheers for the help....
well im defianetly after a manual and a turbo(why buy a nonturbo) :P
colour aint really an issue
mods ain't to much of an issue as long as of got a good base to work from.....
got up to $20G to spend
Hi Niz ;)
yeah you would reckon that with almost 300 Hp at the wheels I could get into the 13's, pity I cant. I could probably whack on the bigger turbo like paul be running 350+ at the wheels and still tun that damn 14.1 :(
Well thats a good start ReVN211... thats basically what I did.... knew I wanted a manual turbo R33 with a GTR rear wing with no GTR badging.... had a look around the importers and found one in really good condition with everything I wanted, and it appears more recently it came with even more I didnt know about :)
    • Thank you for the feedback bro. Looks like it’ll have to stay off the road till it gets an ecu
    • Only if you do not You will not be able to drive it with any serious load without risk of it pinging, which will either slowly or rapidly kill it, depending on how bad it is.
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
