  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I believe R32's are quite a bit harder to find at the moment than the 33's..... You really want to have some idea in your mind about what you are looking for ( either 32/33 , manual/auto , turbo/non turbo, colour? , modded/stock , cheap(maybe needs a bit of work?) or one that may cost a bit more but is in better condition )and then start to have a browse around and just see whats out there..... plus there are a couple of guys on here looking to get rid of there skylines too dont forget :P
Originally posted by MrGTST
I believe R32's are quite a bit harder to find at the moment than the 33's..... You really want to have some idea in your mind about what you are looking for ( either 32/33 , manual/auto , turbo/non turbo, colour? , modded/stock , cheap(maybe needs a bit of work?) or one that may cost a bit more but is in better condition )and then start to have a browse around and just see whats out there..... plus there are a couple of guys on here looking to get rid of there skylines too dont forget :(
cheers for the help....
well im defianetly after a manual and a turbo(why buy a nonturbo) :P
colour aint really an issue
mods ain't to much of an issue as long as of got a good base to work from.....
got up to $20G to spend
Hi Niz ;)
yeah you would reckon that with almost 300 Hp at the wheels I could get into the 13's, pity I cant. I could probably whack on the bigger turbo like paul be running 350+ at the wheels and still tun that damn 14.1 :(
Well thats a good start ReVN211... thats basically what I did.... knew I wanted a manual turbo R33 with a GTR rear wing with no GTR badging.... had a look around the importers and found one in really good condition with everything I wanted, and it appears more recently it came with even more I didnt know about :)
    • Sorry I didn’t explain myself properly, by free revving I meant if I just floor it, it gets to 7kish and will start to break up/not hit limiter properly, off boost I’ve driven the car until near on empty. I have a fuel pressure gauge mounted in the engine bay, holds fuel pressure consistently full tank or half tank even when revving, and no the pump sound doesn't change. all the fuel lines inside the tank are fairly new but will look into it, could that also be an issue with the lines outside the tank ?
    • Yeah maybe I got a bad batch that only lasted 6 years. Or conversely maybe I got a good batch that managed to last 6 years.    Either way I have sourced a set of OEM hub/bearing assemblies  so I keep hearing! Even from life long mechanics. Apparently this failure is unheard of…
    • I am trying to understand how that even happened to the hub... wtf
    • Hell, I'm sufficiently wary of the ZSS suspension arms, let alone something like a hub.
    • Got it back home and got started pulling the hub off and diagnose the issue. Axle was stuck after removing the 36mm nut so i used a 3 jaw puller to try and push it out and... eH5FXvJ8.mp4   spend the next few hours trying to remove the axle from the remaining hub as it was very much jammed in there when the spindle sheared off. resulting damage as below R53AIy6 - Imgur.mp4   Looks like the was already a stress fracturing in the spindle as can be seen with the darker cracked section My working theory is maybe when the pinion gear exploded last year the shock put through the hub was the initial crack. Then a few events later it finally let go. Just lucky it happened where it did and not 190km/h on the next sweeper or into the hairpin The bearing/hub assembly went in in 2019 and were non-genuine "ZSS" assemblies and no nails were harmed in the process. #BreakHubsNotNails
