  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Ha , for the quality os service and some smug guy giving me the eye over the counter I am doing my own.......
I don't trust anyone any more........
TNO..........good rego
I am good at hearth!!!
And I take the first punch. Just pray I dont get back up............Industrial Relations Babay and ACCC!!!
Just to ****in prove the point...
Paul,
Rockingham is great, nothing happening where I live in the center, but the influx of scum from Kwinana and Northern Suburbs is bad in Waikiki is bad...... Better property here for the price.......50k from the city UNI TAFE, Super Cheep AUTO hahahaha :P
It's ok, better than Morley!
Where do you work?
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
