  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Personal Assistant/ Marketing Assistant to Dealer Principal ....... comes with car n petrol too ... which is nice but the job also looks A1 .... i always wanted to do marketing. :)
How very courageous of you blokes. I knew youd come and sook in this section, and hide behind your keyboards.
To try and set things straight. You guys may think that I screwed Ken over, but listen to this first before you pass judgement.
I had an offer from him, which I wasnt too happy about, since it was a few grand lower than my minimum. But stupidly I told him that yes that would be enough. I also asked for a deposit which he declined.
About 3 hours later, I had an offer of a couple grand higher (my minimum) to which I said I will have to talk to Ken first about. I told Ken, and he couldnt match the offer so I then took the higher offer.
Now call me a wanker or whatever you like, but I think if you guys were put in the same situation then youd probably do the same thing.
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
