  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Personal Assistant/ Marketing Assistant to Dealer Principal ....... comes with car n petrol too ... which is nice but the job also looks A1 .... i always wanted to do marketing. :)
How very courageous of you blokes. I knew youd come and sook in this section, and hide behind your keyboards.
To try and set things straight. You guys may think that I screwed Ken over, but listen to this first before you pass judgement.
I had an offer from him, which I wasnt too happy about, since it was a few grand lower than my minimum. But stupidly I told him that yes that would be enough. I also asked for a deposit which he declined.
About 3 hours later, I had an offer of a couple grand higher (my minimum) to which I said I will have to talk to Ken first about. I told Ken, and he couldnt match the offer so I then took the higher offer.
Now call me a wanker or whatever you like, but I think if you guys were put in the same situation then youd probably do the same thing.
    • I downloaded the apps (for windows) and Consult 1 doesn't have this function on it for the Consult 1 plug which I'm pretty sure all Skylines have. You would think someone would have a workaround after 30 years for all Skylines which have ABS.
    • Also, I don't know the actual ABS system on the skylines, but a sneaky thing could be a piece of electronic equipment that makes the ABS think you're moving, and then same piece can send a signal for a locked up tyre... Activate ABS without slamming brakes...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
