  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Personal Assistant/ Marketing Assistant to Dealer Principal ....... comes with car n petrol too ... which is nice but the job also looks A1 .... i always wanted to do marketing. :)
How very courageous of you blokes. I knew youd come and sook in this section, and hide behind your keyboards.
To try and set things straight. You guys may think that I screwed Ken over, but listen to this first before you pass judgement.
I had an offer from him, which I wasnt too happy about, since it was a few grand lower than my minimum. But stupidly I told him that yes that would be enough. I also asked for a deposit which he declined.
About 3 hours later, I had an offer of a couple grand higher (my minimum) to which I said I will have to talk to Ken first about. I told Ken, and he couldnt match the offer so I then took the higher offer.
Now call me a wanker or whatever you like, but I think if you guys were put in the same situation then youd probably do the same thing.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
