  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i have the biggest splitting headache ..... just downed a couple of panadol in the hope it'll go before interview .... which i slooming rather quickly. I think i'll let the boss know what happened today in the hope he'll understand why im not so bubbly ..... cos for this position you have to deal with customers a bit and today i just look like death warmed up.
well just come back from mhy interview but on the way there the neighbours cat decided to run out in front of me and if it wasnt for some good brakes that had already been well used today and a big mo-fo horn it wouldve been roadkill. Theb a few kms up the road a 4wd decides to cut the corner and almost finish up whats left of my front end.
WHAT IS IT WITH ME TODAY??
its like im cursed ...... everything i touch turns to disaster.
And i love the job although they are really concerned with my age and how im going to handle "the boys" :P ...... and to tell you the truth as much as i would like the job im too physically and mentall ystuffed today to begin on the many reasons why they should employ me ..... im basically of the attitude "Are you going to give me the phucking job or not" today!
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
