  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i have the biggest splitting headache ..... just downed a couple of panadol in the hope it'll go before interview .... which i slooming rather quickly. I think i'll let the boss know what happened today in the hope he'll understand why im not so bubbly ..... cos for this position you have to deal with customers a bit and today i just look like death warmed up.
well just come back from mhy interview but on the way there the neighbours cat decided to run out in front of me and if it wasnt for some good brakes that had already been well used today and a big mo-fo horn it wouldve been roadkill. Theb a few kms up the road a 4wd decides to cut the corner and almost finish up whats left of my front end.
WHAT IS IT WITH ME TODAY??
its like im cursed ...... everything i touch turns to disaster.
And i love the job although they are really concerned with my age and how im going to handle "the boys" :P ...... and to tell you the truth as much as i would like the job im too physically and mentall ystuffed today to begin on the many reasons why they should employ me ..... im basically of the attitude "Are you going to give me the phucking job or not" today!
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
