Job: the one i applied for: told wont know anything til Thursday week. They had a few applicants i think to interview .... so good luck to him.
Dude wheres my car .... attached to the front of your bunky: Revn is getting his address from the rego number ..... decide what to do from there :( Car went into panel beaters today .... my self esteem is taking a battering driving round in the Laser (time to get ZX reinsured!!)
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Cam in meeting :( be out 4pm
Yeah Dan i want something similar ...... big sticker .... this is not my car i do drive a very hot R33 ..... honestly .... and the reason why its in the panel beaters is not because im a women driver.
Yep they should pretty much straighten things out.
hey denver
Originally posted by zanda
you have reported int to the police havent you niz??
Whats the point? .... i have no witnesses ..... and even some of the events that took place im sketchy on ....... technically he shouldve hit me passengers door .... but he hit me face on .... full on ... how the hell that happened i dont know ......
ummmmm ok whats badger and mushroom business.
i had an accident $1,300K worth of damage to his car (yeah right it was a $500 telstar that you couldnt even see where i nudged him!) and it wasnt reported ...... that one was my fault but my view was obstructive by two big buses! Besides .... my damge is free .... dad said that if i take him to court i could get $2K in my pocket tho ..... mmmmm intercooler .... but i dont have any witnesses ..... hey guys wanna be my witnesses :(
thanks bam i'll give you your 10% of the $2k later :D:(
hmmm never beenin a cop station before - i find it daunting ..... these people ive been trying to advoid for my whole driving life ..... why seek them out and stir the beast?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
