  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
2 mins to remove a GT wing ehhhh ........ geez even i could do that :evil:
Back - evacuation was about as interesting as watching paint dry
yes Alex im a contractor ..... im not even that .... im a temp but *ssshhh it says govt contractor on the organisational structure so the big bosses dont realise that they have temps still employed*
Havent really had net acess much so i havent bothered.
Working again next week for a month though so ill be around a bit more.
I want to get all my crew down to do a run. Deesh has a new s15 which needs a look and i dont think caine has run his mr2 yet. or gradenko his new bits and pieces.
hmmm quiet ...... wake up everyone im here!! :)
going to drags next week no point going two weeks in a row .... i dont run my car and even if i wanted to i dont have a car to run ..... apart from the Laser ...... go the Laser :)
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
