  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
2 mins to remove a GT wing ehhhh ........ geez even i could do that :evil:
Back - evacuation was about as interesting as watching paint dry
yes Alex im a contractor ..... im not even that .... im a temp but *ssshhh it says govt contractor on the organisational structure so the big bosses dont realise that they have temps still employed*
Havent really had net acess much so i havent bothered.
Working again next week for a month though so ill be around a bit more.
I want to get all my crew down to do a run. Deesh has a new s15 which needs a look and i dont think caine has run his mr2 yet. or gradenko his new bits and pieces.
hmmm quiet ...... wake up everyone im here!! :)
going to drags next week no point going two weeks in a row .... i dont run my car and even if i wanted to i dont have a car to run ..... apart from the Laser ...... go the Laser :)
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
