  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
but, but, but Rx7's dont have that much of the light showing their pop up lights are smaller n gayer .......
Niz goes off to find more proof..........
Go clean the house or do something useful with your life :P
