  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hello. Yeah the peak power reading was a bit disappointing, but the midrange of the car is huge. Comes on boost quicker and has plenty of torque to wack you back into the seat. Going to need a new manifold sometime as the stock one is shite and falling apart on me, plus with the better flow I think the car will make a bit more power, probably closer to 350-360hp peak with more timing in the top end.
Al, Although it is for SAU, the idea is to show us participating in events with the other cars. We're not all Skyline owners, so showing other Jap Imports and other cars of interest is cool. You have to show things like the GT40, some of the WRX's etc, cause although there not Skylines there still pretty cool:D
Ok Paul, but no Comodores......
Still there is some nice footage....but I need some more style appart from the driving events.....body kits.....tyres mags..
parking shots.....people talking....
I wish we shoot the Modras Bay meeting group....looked awesome in the wind.....I got photos.....and I can use photos as well.....tell me where......
Roc'N'rollllll
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
