  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Aidwin,
Here is Brett's list if it helps you do yours:D
Car Details:
1995 Nissan Skyline GTR Vspec
Midnight Purple Paint
Engine Mods:
RB26DETT with standard internals
HKS 2530 Turbo’s
HKS Split Dump Pipes
RSR hand made front pipes and 3” exhaust
HKS Type R (600 x 300 x 103) Intercooler
HKS Adjustable Cam Gears
Cusco Catch Can
Z32 80mm Air Flow Meters
K&N Pod Filters
Sard 700cc injectors
Nismo 280ltr/hr Fuel Pump
Power FC Pro ECU with FC Commander and Boost Kit
Suspension and Wheels:
Stock Vspec Suspension
Impul 18 x 9” Multi piece polished Rims
245/45/18 Goodyear Eagle F1 DSG3 tyres
Interior:
Defi-Link Boost and Exhaust Temperature Gauges
Greddy Twin A Pillar mount Gauge holder
Nismo Short Shift kit
Nismo Gear knob
Stereo:
Alpine Deck
MB Quart 6.5” Spilts in front
Alpine V12 2 channel amp running splits
2 x 12” Rockford Fosgate Subs in box
Rockford Fosgate Punch 250 amp running subs
Lightning Capacitor.
A DINNER CONVERSATION GONE WRONG...
WIFE: "What would you do if I died? Would you get married again?"
HUSBAND: "Definitely not!"
WIFE: "Why not - don't you like being married?"
HUSBAND: "Of course I do."
WIFE: "Then why wouldn't you remarry?"
HUSBAND: "Okay, I'd get married again."
WIFE: "You would? (with a hurtful look on her face)."
HUSBAND: (makes audible groan).
WIFE: "Would you sleep with her in our bed?"
HUSBAND: "Where else would we sleep?"
WIFE: "Would you replace my pictures with hers?"
HUSBAND: "That would seem like the proper thing to do."
WIFE: "Would you play golf with her?"
HUSBAND: "I guess so."
WIFE: "Would she use my golf clubs?"
HUSBAND: "No, she's left-handed."
WIFE: - - - silence - - -
HUSBAND: "Shit."
What were you doing with a torch boosty?
aghhh! this chick im doing her job while im away gave me a list of documents to use but do i have access to them? nooooo - so they are absolutely no phucking use to me & everyone is expecting me to do this stuff and ive had no training in - im not phucking pyschic!!
cool last time i went to Perth Cup was an absolute disaster .... i had to go to the Emergency Room :P
Melbourne Cup at Ascot was way better ....... oh so hammered haha nah that rocked!
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
