  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Aidwin,
Here is Brett's list if it helps you do yours:D
Car Details:
1995 Nissan Skyline GTR Vspec
Midnight Purple Paint
Engine Mods:
RB26DETT with standard internals
HKS 2530 Turbo’s
HKS Split Dump Pipes
RSR hand made front pipes and 3” exhaust
HKS Type R (600 x 300 x 103) Intercooler
HKS Adjustable Cam Gears
Cusco Catch Can
Z32 80mm Air Flow Meters
K&N Pod Filters
Sard 700cc injectors
Nismo 280ltr/hr Fuel Pump
Power FC Pro ECU with FC Commander and Boost Kit
Suspension and Wheels:
Stock Vspec Suspension
Impul 18 x 9” Multi piece polished Rims
245/45/18 Goodyear Eagle F1 DSG3 tyres
Interior:
Defi-Link Boost and Exhaust Temperature Gauges
Greddy Twin A Pillar mount Gauge holder
Nismo Short Shift kit
Nismo Gear knob
Stereo:
Alpine Deck
MB Quart 6.5” Spilts in front
Alpine V12 2 channel amp running splits
2 x 12” Rockford Fosgate Subs in box
Rockford Fosgate Punch 250 amp running subs
Lightning Capacitor.
A DINNER CONVERSATION GONE WRONG...
WIFE: "What would you do if I died? Would you get married again?"
HUSBAND: "Definitely not!"
WIFE: "Why not - don't you like being married?"
HUSBAND: "Of course I do."
WIFE: "Then why wouldn't you remarry?"
HUSBAND: "Okay, I'd get married again."
WIFE: "You would? (with a hurtful look on her face)."
HUSBAND: (makes audible groan).
WIFE: "Would you sleep with her in our bed?"
HUSBAND: "Where else would we sleep?"
WIFE: "Would you replace my pictures with hers?"
HUSBAND: "That would seem like the proper thing to do."
WIFE: "Would you play golf with her?"
HUSBAND: "I guess so."
WIFE: "Would she use my golf clubs?"
HUSBAND: "No, she's left-handed."
WIFE: - - - silence - - -
HUSBAND: "Shit."
What were you doing with a torch boosty?
aghhh! this chick im doing her job while im away gave me a list of documents to use but do i have access to them? nooooo - so they are absolutely no phucking use to me & everyone is expecting me to do this stuff and ive had no training in - im not phucking pyschic!!
cool last time i went to Perth Cup was an absolute disaster .... i had to go to the Emergency Room :P
Melbourne Cup at Ascot was way better ....... oh so hammered haha nah that rocked!
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
