  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I like to wave to people. I wave to people when im in Gradenkos car mostly, some people wave back thinkin " do i know that guy?" Gradenko freaks out, he dont like it much, but i guess thats why i do it. When i had the supra i waved at almost all imports and gave the "jerky jerky" sign to all the ricers.
Hmm maybe thats why i think that 30% of all cars are skylines. :confused:
yeah i always wave to Skylines ....... well ok i mainly only wave to R33's ... when they are over the other side of the road ..... when they are on my side of the road ..... then its all business :P
I get a helluva a lot of Silvias waving to me and they usually get the confuddled "do i actually know you or you just waving to me cos i drive an import" look
U gotta make sure u got the wave down too.
For the passenger u have to have ure forearm vertical and it rotates at the elbow and the fingers stay together, just like the queen. For the driver its always the ultra classy 3 fingers off the wheels stylz.
when i drove my ZX i used to get people in Z32's wave to me i felt like "ahhh im accepted" :P
haha i still get Z32 guys talk to me at the lights ...... usually just before they take off i get "Oh by the way - this isnt my girlfriends followed by a .... ;) "
Yeh i noticed that. When the traffic picks up it starts to tick u off. No1 does it on the coast roads though.
Apparently that stemmed from ye old days when there was no tempered glasss and people used to touch the windscreen so it didnt break if a rock hit it. Shockies for ure glass.
haha yeah can be a bit snobby sometimes.
But its cool when you have a bit of a run with another car then you pull up at the lights and htey'll ask you whats in it and you have a convo. Like that guy in the Pulsar .... he was such a sweety. 240rwhp on a Pulsar ..... no wonder i was eating his dust .... i was ready to march my car down to the car yard til i found out what was in it then losing didnt seem so bad.
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
