  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Shaun it had an SR20 (?) motor in it ..... and turbo'd .... and the way that thing moved - he wasnt pulling my leg ..... made my car look like the Laser im currently driving ... .very embarrassing.
So true, those things are too much fun. I know a guy that crashed his 6 times in 8 months and his parents fixed it each time. Apparently there was one incident where he decided he had right of way over the oncoming traffic just becasue his car was a silvia. So hes hanging out the window screaming "the silvia has right of way u stupid *****" the woman in the other car was just dumbstruck and let him through. Hes not a bad guy, just a moron.
haha no doubt theres some good silvia drivers out there but all the ones i come across are 17yr old Eminiem Tryhards that try and take you on and just get slaughtered ..... ask Liz haha she had a go at them as well ..... it was two chicks in two black Skyline flying in formation .... they were the days!!
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
