  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Paul prolly about 10-12 cars if the plan goes together, im not organising it, just hopefully doing some demoing..
but all ive told about it and told to come for some practice are fairly good at it, couple of the c-red crew are comming, bunch of the SW crew, few others, should be good fun
