  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i need everyones opinion!!
The SAFC II .... blue or ltd edt Grey?
http://www.greenline.jp/catalogue/btlist2....0and%20Monitors
normally wouldnt even consider grey cos blue is far prettier but theres two reasons why im undecided between the two.
A. The blue really sticks out and screams come steal me to anybody looking into your car .... where the grey is more camoflauged in with my interior
B. Its Ltd Edition so could hold its value more ..... but its not like im getting rid of my car nor going to go down the Engine managment path and need to sell it.
:confused: someone just make a decision for me pluheeez!!
well Greenline do both ... but slightly more expensive than Nengun .... although Nengun havent given me their postage prices yet.
How much do you think it would weigh for postage .... i worked out to be not over 1.25kgs ...... and i doubt its that even but i thought with the box etc ... about $450 on that ..... but it'll probably be less.
Nengun only do the blue and dont have special edition .... hmmm choices choices!! maybe i should just i draw out of a hat. Oh well if Nengun are cheaper then my mind i guess is made up for me :)
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
