  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i remember the good old days in tafe doing info tech learning to hack a password from a pay site. 2 friends got banned from their ISP for it, no legal dramas or fines though which was good.
so paul just the goat then?
dude no dramas on the bov, its the insurance mate.
I will sell the car to you UBER cheap, if you can get the insurance.
tame this!!!
** Posted: Today at 8:07 am
# : BBlorenzo : xYXcrEu8TTqD Proxy used: 210.220.73.9:80
# : BBmanuel99 : PHoIUOFtzgHk Proxy used: 193.251.169.170:80
# : BBmasena-2 : WkHxQ2g7i5NZ Proxy used: 193.251.169.171:80
# : BBmeuchelmorder : 76dp15KaLqtd Proxy used: 194.126.30.138:3128
# : BBoakville : 33IkHVaWRcQO Proxy used: 81.40.35.0:80
# : BBoninoken : YA6TsGfJwG9S Proxy used: 81.40.9.255:80
# : BBPSolace : q5aG2tHl1EPq Proxy used: 211.46.218.97:8080
# : BBpoolboy2310 : Ok6TXUtSUapj Proxy used: 210.95.49.3:8080
# : BBprickolini : reMr3Yifthjm Proxy used: 194.132.65.254:80
# : BBprince37 : UlJQwJgfl2HZ Proxy used: 211.57.78.2:8080
i dont pay much at all for mine, but I am hooked up.
if more people got to me before the friggin fraudulent claim we had with a certain R34 that used to be on these forums then all would still be fine and even 13_devil would have insurance.
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
    • lol already been put in temporarily 3 years ago
    • Makes sense. For actuators, if the pressure itself isn't adjustable, that would mean I'd need to think about 2 different actuators with 2 different pressures on paper in order for them to work at the same time if the turbos behave differently. So measure the difference in psi needed to move both, and then get an actuator to match that difference. Assuming I cant get rid of it by adjusting the arms.  You're exactly right, never happens in gear 1 or 2. I can occasionally get it in gear 3 if going uphill but its very small. Only ever in 4 and 5. Seems kind of backwards that one of the points of VCAM is faster spool but if it introduces shuffle then it actually slows spool down.
