  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hahaha newbie
dude the wold 3d is plug and play purely because its loom will plug into a skyline factory LOOM not a skyline factory computer
your old ecu goes in the bin when the wolf steps in
plug and play has nothing to do with piggyback
dont forget that
the wolf is the best value especially cos SST can tune then etc really well.
has boost control and everything already built in
bargain
each ecu is only as good as the tuner alot of the time
SST can really do his shit with the Wolf
there is alot of horsepower hiding in better maps alone
i dont know anyone who can do emanage
power fc is your next best bet, cos its awesome
but you will pay about $1600 for a secondhand powerfc with a hand controller and possibly the boost control module for it. then you gotta get it tuned.
the wolf is like drive away tuned at $1500 or so
